32KB Dual Port Video RAM
A project log for SPAM-1 - 8 Bit CPU
8 Bit CPU in 7400 with full Verilog simulator and toolchain
John LonerganJohn Lonergan 10/01/2022 at 19:422 Comments
Started a new module to support the VGA component of SPAM-1.
I wanted 32KB of dual port ram for video but wasn't willing to shell out for it. I found a couple of 16KB PLCC modules so I need a board to support them as part of SPAM-1 and the new sub-project is a PCB to create a 32KB module that's R/W from the CPU side and Read-only from the GPU side and fast enough for 160x120 approx video.
It's a work in progress.
https://oshwlab.com/john.lonergan.sharing/32kb-dual-port-video-memory
I want it to fit amongst my breadboards so it's size constrained.
John Lonergan wrote 10/02/2022 at 19:14 point
Thanks. Even better when the parts arrive, which are hopefully not counterfeit and then integrated into SPAM-1.
Definitely the simplest approach is to implement something like the ansi or VT escape codes. But not today.
Augusto Baffa wrote 10/02/2022 at 12:49 point
Pretty cool !
