Timing is Everything
A project log for SPAM-1 - 8 Bit CPU
8 Bit CPU in 7400 with full Verilog simulator and toolchain
john-lonerganJohn Lonergan 08/29/2019 at 14:560 Comments
Researching Propagation Delays
One might at some point ask a question "what limits the speed of a CPU?". In most circuits the speed limit probably comes down to the well documented timing limitations of the components you've chosen to use. To be fair factors such as capacitance, or even inductance, damping out or creating higher frequency signals might complicate things but I haven't the experience to say the extent of the role that capacitance and inductance play in limiting home brew CPU speeds; CPU's that run 10MHz or less. My instincts tell me that capacitance and inductance are unlikely to be a huge concern unless attempting to run at higher frequencies and in any case these factors would probably by highly dependent on the specific layout of one's CPU.
We know that running a home brew CPU in the 1MHz-5MHz range is entirely feasible and it's easy to find folk doing this, such as Warren Toomey and his CSCvon8.
Why not faster?
State changes in electronics are fast but not instantaneous. All electronic components have delays around the time needed to setup the inputs of the component and/or delays between an input changing and the output of the component reacting to that change. During these intervals the outputs of the component cannot be relied on to be have a stable and deterministic value and these kinds of delays put a hard limit on how fast one can run a given component.
Timing diagram - propagation delay
In addition, many components will state how long the inputs of the device (eg the data in of an latch) must be held stable prior to a trigger or enable signal. If the inputs are not held stable sufficiently long prior to the trigger then the data seen by the device is unpredictable; ie potentially random behaviour.
edge timing pre and post
When we put several components together in a circuit then the individual delays of the component sum up on the critical path of the larger circuit to further reduce the maximum operating frequency of the circuit as a whole.
For example, consider the logic around an instruction that latches a constant from the program memory into a register. The program memory, eg a ROM, will have associated control logic around it and the output of the ROM will loaded into a register and all those components will have their own delays.
For example, lets say the control logic, a 74HCHCT151 multiplexer, takes 25ns to stabilise the output enable flag on the ROM, the ROM, a AT28C256-15, takes 150ns to display the new data value and finally the register, a 74HCT374, takes 12ns to latch the ROM output, then the critical path through those components is 187ns. In this case then the fastest one could expect to operate this path would be of the order of 5.3Mhz ( = 1 divided by 0.000,000,187).
And depending on the choice of components this max clock rate could be considerably less. For example, if instead we choose the slower AT28C256-35 ROM then we are looking at a tACC (time from address to data output stabilisation) or tCE(time from chip enable to data output stabilisation) of 350ns, which would mean a max frequency of no more than 1/(25+350+12) = 2.5Mhz approx.
All the calcs above are approximations from the data sheets (which I may have misread) but the principal stands that longer delays in the individual components translate to lower operating frequencies for the CPU.
If one uses a more sophisticated simulation or modelling tool than Logisim then the tool will probably calculate your critical path for you and tell you the timings. The critical path is the slowest path and thus the path likely with the greatest impact on speed.
Most of the time I figure you can work it out roughly like I have above and then decide if you want to make adjustments to your design.
One significant improvement to the 150ns ROM example given above might be have the ROM contain a simple boot program that copies the program code from ROM into a much faster SRAM chip at power-on and then run the program entirely from the SRAM. For example, it is easy to find 32Kx8 SRAM chips with 20ns read cycle time instead of the 150ns EEPROM and this might get the CPU clock up to speeds closer to 10MHz. I've not tested that yet of course, but you get the idea.
More info on propagation delays can be found in the MIT Computational Structures lecture notes which are quite detailed. And, of course, don't forget to look in your data sheets.
Clock Domain Crossing
If interested in clocks and timing then you should also take a look at Warren Toomey's answer to a question I posed him on clock timing where he goes into a lot of useful and interesting details (thanks).
However, Warren also pointed me to a page about "Clock Domain Crossing" which I think bit me a while back when I was doing something "clever" with dividing my clock. I did it badly and started experiencing an issue where I got two clock pulses when expecting only one. I figured out on my own that my stupid divider wasn't reliable but didn't have any clue what the technical term for my stupid problem was. I am now wiser thanks to Warren and I advise you to visit that link also.
I know that the comments section in one of Ben Eater's vids contains a bunch of folk talking about why he didn't just "gate the clock" or something like that as it would have been easier.
I will now paraphrase the whole thing as "don't mess with the clock!".
Advice on clocks for newbies
Please also go and read the "Rules for new FPGA designers" page regardless of whether you are planning an FPGA or discrete IC based design. This page is linked off the Clock Domain Crossing page that I mentioned earlier.
You'll see immediately that I (also Ben Eater and others) violate rule 2 by having the PC advance on one edge and the execution firing on the other edge. In fact that same page says that this setup "acts like separate clocks", which I agree with. They act like inverse clocks and Ben Eater even says we need inverse clocks in one of his vid's. The important point is knowing what the options are and the pro's and con's then making an informed decision (and simulating first !!!).
Like myself, Warren Toomey also had a signal glitch problem in the Crazy Small CPU build that was resolved by bringing the clock signal into the logic. He discusses the problem in Crazy Small CPU #13 at about 2m27s. The approach of brining in the system clock is also cited on the newbie advice page as a potential solution to such problems.
The same newbie advice page gives useful guidance on synchronising buttons and other external inputs with the system clock. Coincidentally the need to synchronise a button press with the system clock came up recently where I had to synchronise the system reset button with the program counter logic and I needed to achieve this by use of a SR latch.
