Hardware
Software Used
Library Used
Arduino Client for MQTT
This library provides a client for doing simple publish/subscribe messaging with a server that supports MQTT
For more information about MQTT, visit mqtt.org.
Download
The latest version of the library can be downloaded from GitHub
Documentation
The library comes with a number of example sketches. See File > Examples > PubSubClient within the Arduino application.Full API Documentation.
Compatible Hardware
The library uses the Arduino Ethernet Client api for interacting with the underlying network hardware. This means it Just Works with a growing number of boards and shields, including:
Wire Library
The Wire library allows you to communicate with I2C devices, often also called "2 wire" or "TWI" (Two Wire Interface), can download from Wire.h
Basic Usage
Transmitting
Receiving
Steps to send data to LabVIEW temperature and humidity platform using IoT Long Range Wireless Temperature and Humidity Sensor and Long Range Wireless Mesh Modem with USB Interface:
Uploading the Code to ESP32 Using Arduino IDE
Serial Monitor Output
Making Ubidots Work
 Click on devices and select devices in Ubidots.
 Now you should see the published data in your Ubidots account, inside the device called "ESP32".
Now you are able to view the Temperature and other sensors data which was previously viewed in serial monitor.This happened because the value of  different sensor reading   is passed as a string and store in variable and publish to variable inside  device esp32.
Create Dashboard in Ubidots
Output
