POD
Back to overview
A focus tool for the digital age. Increase focus, boost productivity, and beat procrastination.
futurshox wrote 09/12/2019 at 21:42 point
Thank you for this project! I found it on Kickstarter. I assembled the two device kits I bought this afternoon. The 3D print files worked like a charm on my Prusa i3 - although I took Artem’s advice on scaling the X&Y by 5% on the dividers - and the electronics assembly was very straightforward. Here’s a picture of the finished items: https://imgur.com/a/PGR9AZE
Artem Golovin wrote 09/07/2019 at 21:55 point
Hi Gary,
I've received the kit, flashed the chip, printed the body and assembled!
The only thing is that I made a few changes to the code. I changed pomodoro intervals to 45m work + 15m break. Plus added a quick blink if it was reset. Here is the code if anyone wants to do the same:
https://github.com/SAGV/POD/
(Make sure you're familiar with Arduino IDE and have a spare arduino + ~10uF capacitor to use it as the intermediate between your laptop and the ATTiny85)
Also I was not able to fit LEDs into the divider whatever I tried. So I increased divider's X&Y dimensions by 5% and kept Z dimension at the same 6mm in Cura. After this little change everything fitted just nicely! (Printed on ender 3)
Works awesome! Thanks!
Artem Golovin wrote 09/07/2019 at 22:00 point
Here are a few pics of the process and a short final video:
https://www.dropbox.com/sh/uekpxp3g1yfuh5o/AAB_DYyoxiTzVfsEclmyxvKqa?dl=0
