3D Printed Frame Design
A project log for DIY EL Wire + 3D Printed "Neon" Sign!
I love the look of neon signs but they aren't particularly easy to DIY without glassblowing skills and equipment, so EL Wire to the rescue!
sjm4306sjm4306 08/07/2019 at 13:280 Comments
So the first step in this project is to obviously choose the sign I'd like to make. In my case I decided on the n64 logo for a few reasons:
- It is colorful with nice vibrant primary colors
- There are already commercially available neon lights which I could borrow the design from (and not have to come up with it myself)
- Finally, it is just a plain cool logo
After a quick google search I found a nice image of the original neon sign which I saved and imported into inkscape for editing.In inkscape I used the trace bitmap command under path to generate the light path using brightness to filter the image to that shown on the right above. Then I drew red dots for where holes would need to be on the frame for the EL wire to poke through and blue dots for support locations to bend the wire around. Finally I made sure the dimensions of the design were scaled to the desired final size I wanted the sign to be. With this done I saved the file as a dxf to allow it to be imported into solidworks.
In solidworks, with the dxf imported as a series of dots (image above) I set it as a construction sketch (yellow inner lines) and began drawing offset lines around the desired shape to form the footprint of the frame (blue lines). I connected all these lines to make a shape with holes where there would be no EL wire to save filament and shorten printing time. From this base shape I extruded upwards to form the 3D shape.
Next I had to make the protruding posts to wrap the EL wire around and give it shape. These were just circles that were extruded outwards and trimmed to match the edges of the frame.
Finally I opted to fillet to round out the pointy edges of the frame (this isn't necessary, but will make it look a little nicer when printed out). The final step for solidworks is to save the design as an stl file so I can import it into cura, my slicer program.
Once in cura (shown above) I can adjust the orientation and location of the print within my 3D printer's bed to ensure it fits as well as adjust parameters like print speed, infill and layer height. I print on a glass sheet from a picture frame I bought at a dollar store clipped to the bed with binder clips coated with a bit of hairspray and it comes out super smooth with great adhesion (but pops off with little effort once cool). The issue in my case is the glass is smaller than my bed area so I have to carefully place the print to ensure it is over the glass and make sure the bed height is correct each print. Other than that, roughly 3 hours later the print finished with no issues and I was ready to assemble. In the next project log we will see the assembly and wiring process to wrap up my first prototype.
