Vacuum UV Curing!
A project log for ADAM DLP 3D Printer
DIY DLP 3D Printer based on NanoDLP Software using Raspberry Pi 3 and Trinamic Motor Controller
adambrxadambrx 03/29/2017 at 15:461 Comment
One of my first attempts of a curing chamber can be seen here. The Model was placed in a diffusion container and submerged in water. The container was placed in a makeshift UV exposure chamber.
The newest build features a custom UV LED fitted vacuum chamber for best results. 10 minutes in the 'oven' and the prints are rock hard.
Iaroslav Kovalenko wrote 04/12/2017 at 13:36 point
You built a nice vacuum chamber! Is there significant difference between vacuum and normal chamber?
