Hi everyone,
I did some progress on the Version 3 prototype, it has more working function then before. I am still facing with some hardware butg, what I inherit from the Version 2. I found out the original circuit has big issues, because I did not had Oscilloscope when I developed the Vesion 2 I could not see these issues before. The Voltage ranges was messed up. Most of the issues I could fix, but it has still some.
A little bit about the spec:
- 6 Voltage range (6 Current range)
- 6 Frequency range
| Ranges | 1 | 2 | 3 | 4 | 5 | 6 |
| Resistance | 250ohm | 2k | 5k | 10k | 15k | 20k |
| Voltage | 0,5V | 1,8V | 3,3V | 6V | 8V | 10V |
| Current | 2mA | 0,9mA | 0,66mA | 0,6mA | 0,5mA | 0,5mA |
| Output | 1mW | 1,6mW | 2,2mW | 3,6mW | 4mW | 5mW |
And the video:
