I mentioned in the last log, I had not too much time build the Curve tracer V2, because of the holidays.
In January I would like to put together the hardware section of the tracker, I did already finish the front of the device, it is looking good I think. After I got the Arduino Due I put ut together with the screen, and started work on the display functions, which is far to be done, but it is something.
The buttons will light up when you selected the mode with them.
I am planning to make a sticker for the front, to hide all mistakes what I made, and also it will looks more professional.
Some picture of the current state:
Hello my friend I hope you are well. I've been following your project here for a while and I see your development with great enthusiasm, but as a constructive criticism I believe that the project's repositories could be better organized, I even tried once to recreate version 1 of your project and fail to follow the necessary steps to conclude because the files are all scattered and without a step organization. Finally, I would like to offer to join the development team, if you could send the files to me more clearly you could propose good ideas to contribute even more to your original goal. I am an engineer and I have experience with product development embedded in the industry and as you believe the community would benefit greatly from such a project. Thanks in advance and I await your return.
