Electronics Assembly and Full Integration Test
A project log for Fetch: A Ferrofluid Display
A 252 electromagnet-matrix that controls Ferrofluid
applied-procrastinationApplied Procrastination 08/10/2019 at 12:240 Comments
Although the project is new here on Hackaday.io, it has already been going on for a while. We have several build episodes on YouTube, but in our most recent video we integrate the full system and test it after first having assembled and tested the electronics.
Everything is open source, and the files can be found below. However, we do not recommend anyone to attempt to rebuild the project in its current state. The electronics especially require a big revision (version 2 will be started later this fall).
Schematics:
https://cdn.hackaday.io/files/1670567147323904/Applied-Procrastination-Fetch-Driver-Circuit-v1r2.sch
PCB Layout:
https://cdn.hackaday.io/files/1670567147323904/Applied-Procrastination-Fetch-Driver-Circuit-v1r2.brd
(work in progress) Firmware can be found on:
https://github.com/SimenZhor/FerroFetchFirmware
