Real Time Clock Module
A project log for Fetch: A Ferrofluid Display
A 252 electromagnet-matrix that controls Ferrofluid
applied-procrastinationApplied Procrastination 12/19/2019 at 19:531 Comment
We've added a small perf-board that breaks out I2C-SDA0 (PIN 18), I2C-SCL0 (PIN 19) and 3.3V (which we for some reason hadn't already expanded). The perf-board also hosts an Adafruit DS3231 Real Time Clock (RTC) Module, which means that we now, after some minor code-adjustments, have a "clock mode" for our display.
When operating in "clock mode", the display will show the time with one minute resolution. Every time a minute has passed, the display will load a new animation from the SD-card and display it. We change modes with a 4-way switch that is yet to be documented (our guess is that the current code might not be self-documenting 😅) .
We'll publish some logs documenting the switch and some buttons we've added, for easier operation, at a later time.
lbunic wrote 11/09/2022 at 10:12 point
Hey Guys,
Would you be open to do art project - I would love to collaborate with you for me next art show. contact me : lbunic@gmail.com
