3DuF
An Interactive CAD tool for Microfluidics
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The design of microfluidic Lab on a Chip (LoC) systems is an onerous task requiring specialized skills in fluid dynamics, mechanical design drafting, and manufacturing. Engineers face significant challenges during the labor-intensive process of designing microfluidic devices, with very few specialized tools that help automate the process. Typical design iterations require the engineer to research the architecture, manually draft the device layout, optimize for manufacturing processes, and manually calculate and program the valve sequences that operate the microfluidic device. The problem compounds when engineers not only have to test the functionality of the chip but are also expected to optimize them for the robust execution of biological assays. 3DuF simplifies the engineering process by allowing the designers to use ideas borrowed from PCB editors to rapid create the design using a library of predefined components and connections.
