So does it work?
A project log for When should I replace my A/C air filter?
How can I spend >$100 and >100 hours to save $1 a year on air filters? They say to replace them every month, but is that really true?
tim-rightnourTim Rightnour 12/10/2020 at 19:050 Comments
It's been at least a year since I fired this thing up.  The short answer is, absolutely, yes.
If we take a look at the histogram below (which I found is the best way to visualize this data) we can see how it trends towards higher and higher readings, until we hit the point around 0.8 or so, which it should definitely have been replaced just before.
So basically, if I watch this graph, I can see when the filter should be replaced.  And it's pretty accurate.  I have been examining the filter visually during the period, and the graph basically matches it.
I ended up building one more of these sensors, but basically just attached 2 BME280's and then wired them in ESPHome, super simple.  Need to install that in one of my other units.  But short answer is, I'm more or less happy with this!
