//Transmitter:
#include <SPI.h>//library to communicate with SPI devices
#include <RF24.h>//library for NRF2401 communication
RF24 radio(7, 8);// CE, CSN
const byte rxAddr[6] = "00001";//create a byte array which will represent the address
int sendingdata[6];
const int xPin=2;
const int yPin=3;
void setup()
  Serial.begin(9600);
  radio.begin();
  radio.setPALevel(RF24_PA_MAX);
  radio.setAutoAck(false);
  radio.setRetries(15, 15);
  radio.openWritingPipe(rxAddr);//set the same address on the receiver side
  radio.stopListening(); //sets module as transmitter
  delay(50);
void loop()
  int pulseX,pulseY;
  int accelerationX,accelerationY;
  pulseX=pulseIn(xPin,HIGH);
  pulseY=pulseIn(yPin,HIGH);
  accelerationX=(pulseX-5050);
  accelerationY=(pulseY-5080);
  Serial.print("Rolling:");
  Serial.print(accelerationX);
  Serial.println();
  Serial.print("Pitching:");
  Serial.print(accelerationY);
  Serial.println();
  sendingdata[0]=accelerationX;
  sendingdata[1]=accelerationY;
  radio.write( sendingdata, sizeof(sendingdata) );
//Receiver:
#include <SPI.h>
#include <RF24.h>
#include <Servo.h>
Servo myservo1;  // create servo object to control a servo1
Servo myservo2;  // create servo object to control a servo2
Servo myservo3;  // create servo object to control a servo3
int pos = 0;    // variable to store the servo
RF24 radio(7, 8);
int acceleration[6];
int buttonPin = 5;
void setup()
  for(int i = 2; i<=4; i++){
    pinMode(i,OUTPUT);
  while (!Serial);
  Serial.begin(9600);
  radio.begin();
  radio.openReadingPipe(0, rxAddr);
  radio.startListening();
  myservo1.attach(9);  // attaches the servo on pin 9 to the servo1 object
  myservo2.attach(10);  // attaches the servo on pin 10 to the servo2 object
  myservo3.attach(6);  // attaches the servo on pin 6 to the servo3 object
  pinMode(buttonPin, INPUT_PULLUP);
void loop()
  if (radio.available())
    bool done = false;
        while (!done)
        // Fetching the data payload
        radio.read( acceleration, sizeof(acceleration) );
        done = true;
        int val0=map(acceleration[0],0,1024,0,180);
        int val1=map(acceleration[1],0,1024,0,180);
        if (val0<-135) {
          myservo1.write(165);              // tell servo to go to position in variable 'pos'
          delay(15);                       // waits 15ms for the servo to reach the position
          if (val1<-110) {
            myservo2.write(130);              // tell servo to go to position in variable 'pos'
          else {
            myservo2.write(95);              // tell servo to go to position in variable 'pos'
        else if (val0>135)  {
          myservo1.write(8);              // tell servo to go to position in variable 'pos'
          if (val1<-110) {
            delay(100);                       // waits 100ms for the servo to reach the position
          }                      // waits 15ms for the servo to reach the position
          else {
            delay(15);                       // waits 100ms for the servo to reach the position
        else {
          myservo1.write(85);              // tell servo to go to position in variable 'pos'
          if (val1<-110) {
          else {
        //for serial observation
        Serial.println("Roll");
        Serial.println(val0);
        Serial.println("Pitch");
        Serial.println(val1);
    else{
      Serial.println("Data not received");
   int buttonValue = digitalRead(buttonPin);
   if (buttonValue == LOW){
      myservo3.write(179);              // tell servo to go to position in variable 'pos'
      Serial.println("Pushed");
   } else {
