The first circuit configuration that I need to test is the classic Arduino blinky project. I downloaded the Arduino blinky program to the PCB's Arduino microcontroller changing the pin from 13 to 3. From here I could wire pin 3 directly to a LED or could drive an LED using NPN, PNP, N-ch MOSFET or P-ch MOSFET transistor.
This controller will help me with my current and future projects.
components avalible:
  • Resistors (330R, 1K, 10K and 100K)
  • Capasitors (10uF, 1uF and 0.1uF)
  • Diodes
  • NPN transistors
  • PNP transistors
  • N-ch MOSFET transistors
  • P-ch MOSFET transistors
  • LDR
  • LEDs
  • Buttons
  • potentiometer
  • Arduino UNO with USB(pin: D2, D3, D9, D10, A0, A1, A2 and A3)
  • Power (Vcc, 5V and 3.3V)
  • I i run out of components, I can use 2 boards.
