➢Step descriptions:
✦Step 1:-These are the components we are going to use.
✦Step 2:-If you are making single sideboard, you must insert 1 jumper.
✦Step 3:-Now transistors and ICs are connected to the board.
✦Step 4:-Now we have to apply solder on it.
✦Step 5:-Now we have to cut all the pins.
✦Step 6:-Solder the back pins.
✦Step 7:-Wash with thinner.'
✦Step 8:-Now let’s cut the pins of transistors and ics.
✦Step 9:-We have these 2 heat sink we will mount both, if you have bigger heat sink so you can add one.
✦Step 10:-Let’s make the positions.
✦Step 11:-We can see the cutting here, you can clean it with the help of bigger drill bit or file, otherwise it may short the transistors.
✦Step 12:-Now we have to apply compound.
✦Step 13:-After this we will apply mica.
✦Step 14:-Connect it with the heat sink.
✦Step 15:-Test the transistor and ics
✦Step 16:-Use 12-0-12 volt 14amp transformer and connect the wire.
✦Step 17:-Connect the speaker socket.
✦Step 18:-AUC socket, connect it as well.
✦Step 19:-Connect it to our colum.
✦Step 20:-Connect the AUX cable, let’s it as well with the phone.
✦Step 21:-Play the music, test it.
Products list:
『1 Capacitor 10uF 』 view more ⇒https://goo.gl/jS1JGs
『1 Capacitor 0.0022uf = 222 』 view more ⇒https://www.utsource.net/itm/p/8344801.html
『7 Capacitor 0.22uf = 224 』 view more ⇒https://goo.gl/fFuHNn
『1 Capacitor 0.47uf = 474 』 view more ⇒https://www.utsource.net/itm/p/8353888.html
『1 Connector 2 Pin (2.54mm) 』 view more ⇒https://www.utsource.net/itm/p/8310125.html
『1 Connector 2 pin (3.96mm) Male 』 view more ⇒https://www.utsource.net/itm/p/8309799.html
『1 Connector 2 pin (3.96mm) Female 』 view more ⇒https://www.utsource.net/itm/p/8297620.html
『1 Connector 3 pin (3.96mm) Male 』 view more ⇒https://www.utsource.net/itm/p/8310110.html
『1 Connector 3 pin (3.96mm) Female』 view more ⇒https://www.utsource.net/itm/p/8297600.html
『4 Diode 1N4007』 view more ⇒ https://goo.gl/phHPEu
『2 IC TDA2030 』 view more ⇒https://www.utsource.net/itm/p/8416171.html
『1 Potentiometer 47K 』 view more ⇒https://www.utsource.net/itm/p/8038957.html
『2 Resistor Watt 1 OHM 』 view more ⇒https://www.utsource.net/itm/p/8294885.html
『4 Resistor Watt 2.2 OHM 』 view more ⇒https://www.utsource.net/itm/p/8294868.html
『3 Resistors 1/4 Watt 100K 』 view more ⇒https://goo.gl/Dk2Nyq
『2 Resistors 1/4 Watt 3K3 』 view more ⇒https://goo.gl/t4o1zD
『2 Transistor TIP35C 』 view more ⇒https://www.utsource.net/itm/p/8424592.html
『2 Transistor TIP36C 』 view more ⇒https://www.utsource.net/itm/p/8181173.html
Video on Youtube:
