massive update and improvements to the library
A project log for Lithium-Ion Battery Monitor Library for Arduino
A simple library to monitor battery voltage in small Arduino projects
matthew-james-bellafaireMatthew James Bellafaire 08/20/2019 at 01:300 Comments
Most of these changes will be applied to the description of the project. Just wanted to give credit to https://hackaday.io/grbn who pointed out that there was a much better way to get the battery voltage using an AVR.
