Portable Raspberry PI Zero
a 3D printed portable computer with a QWERTY keyboard
My main goal for this is to have a QWERTY keyboard on a portable device that will be able to program Arduinos in the wild or hack around with the console and look all weird in public places and stuff. I've watched enough episodes of Ben Heck to feel safe to build this ;)
This will hopefully feature an ESP12E module as a well for wifi.
ModuleStateNotes
WiFi👍🏼
Display👍🏼👎🏼
Attiny Display brightness controller
Keyboard over I2C👍🏼👎🏼
Power👍🏼👎🏼
Standard Tesselated Geometry - 1018.34 kB - 11/01/2016 at 07:21
Download
123dx - 206.27 kB - 11/01/2016 at 07:21
Download
Standard Tesselated Geometry - 358.48 kB - 10/31/2016 at 19:09
Download
Standard Tesselated Geometry - 163.36 kB - 10/31/2016 at 19:09
Download
123dx - 123.26 kB - 10/31/2016 at 19:09
Download
View all 6 files
  • 1 × ILI9340C or ILI9341 320x240 PSI TFT LCD display
  • 1 × Raspberry PI zero
  • 46 × OMRON B3F 1000 tactile switches 23 per board, very low force
  • 1 × 3D printer access
  • 1 × 1A 5V boost / step up converter the long blue one on eBay
View all 6 components
  • I2C on an Attiny85
    davedarko01/01/2017 at 21:47 0 comments
    So I thought I would just add the Attiny85 family to the boards by adding the following link to my Additional Boards Manager URLs in my Arduino 1.6.9 IDE and get away with it and use the wire library to hack a little LED PWM backlight controller together. But since that didn't work for the tone() lib on the #Nyan Board , why would it here?
    https://raw.githubusercontent.com/damellis/attiny/ide-1.6.x-boards-manager/package_damellis_attiny_index.json
    So I then look around and find this library on GitHub https://github.com/rambo/TinyWire and with it's help I was able to whip together the LED controller! The idea here is that the pin 3 is connected to the PI and when toggled will write the PWM to pin 4. This PWM value can be set via I2C address 0x04.
    #define I2C_SLAVE_ADDRESS 0x4
    #include <TinyWireS.h>
    int pwm_value = 127;
    #ifndef TWI_RX_BUFFER_SIZE
    #define TWI_RX_BUFFER_SIZE ( 16 )
    #endif
    void setup() {
      TinyWireS.begin(I2C_SLAVE_ADDRESS);
      TinyWireS.onReceive(receiveEvent);
        pinMode(3, INPUT);
        pinMode(4, OUTPUT);
    void loop() {
      TinyWireS_stop_check();
      writeLed();
    void writeLed()
      if (digitalRead(3) == HIGH)
          analogWrite(4, pwm_value);
        else
          digitalWrite(4, LOW);
      void receiveEvent(uint8_t howMany)
        if (howMany < 1)
            // Sanity-check
            return;
        if (howMany > TWI_RX_BUFFER_SIZE)
            // Also insane number
            return;
        // ignore write address
        TinyWireS.receive();
        howMany--;
        if (!howMany)
            // This write was only to set the buffer for next read
            return;
        while(howMany--)
          pwm_value = TinyWireS.receive();
  • changing pins works!
    davedarko11/27/2016 at 21:06 1 comment
    I've mapped pin12 and pin13 to play audio! woot.
    The following code is not mine and taken from:
    https://www.raspberrypi.org/forums/viewtopic.php?f=44&t=39138
    I just want to have everything in one place and have a copy of it somewhere.
    Utility to switch Raspberry-Pi GPIO pin functions
    Tim Giles 01/04/2013
    Usage:
    $ gpio_alt -p PIN_NUMBER -f ALT_NUMBER
    Based on RPi code from Dom and Gert, 15-Feb-2013,
    and Gnu getopt() example
    #include <ctype.h>
    #include <stdio.h>
    #include <stdlib.h>
    #include <unistd.h>
    #include <fcntl.h>
    #include <sys/mman.h>
    #define BCM2708_PERI_BASE        0x20000000
    #define GPIO_BASE                (BCM2708_PERI_BASE + 0x200000) /* GPIO controller */
    #define PAGE_SIZE (4*1024)
    #define BLOCK_SIZE (4*1024)
    int  mem_fd;
    void *gpio_map;
    volatile unsigned *gpio;
    void setup_io();
    // GPIO setup macros. Always use INP_GPIO(x) before using OUT_GPIO(x) or SET_GPIO_ALT(x,y)
    #define INP_GPIO(g) *(gpio+((g)/10)) &= ~(7<<(((g)%10)*3))
    #define OUT_GPIO(g) *(gpio+((g)/10)) |=  (1<<(((g)%10)*3))
    #define SET_GPIO_ALT(g,a) *(gpio+(((g)/10))) |= (((a)<=3?(a)+4:(a)==4?3:2)<<(((g)%10)*3))
    #define GPIO_SET *(gpio+7)  // sets   bits which are 1 ignores bits which are 0
    #define GPIO_CLR *(gpio+10) // clears bits which are 1 ignores bits which are 0
    int main (int argc, char **argv) {
      int opt, flag, n_pin, n_alt;
      flag=0;
      while ((opt = getopt (argc, argv, "hp:f:")) != -1) {
        switch (opt) {
        case 'h':
          break;
        case 'p':
          n_pin = atoi(optarg); flag |= 0b0001; break;
        case 'f':
          n_alt = atoi(optarg); flag |= 0b0010; break;
        case '?':
          // getopt() prints error messages, so don't need to repeat them here
          return 1;
        default:
          abort ();
      if (flag != 0b0011) {
        fprintf (stderr, "Usage:\n$ gpio_alt -p PIN_NUM -f FUNC_NUM\n");
        return 1;
      setup_io(); // Set up gpi pointer for direct register access
      INP_GPIO(n_pin);  // Always use INP_GPIO(x) before using SET_GPIO_ALT(x,y)
      SET_GPIO_ALT(n_pin, n_alt);
      printf("Set pin %i to alternative-function %i\n", n_pin, n_alt);
      return 0;
    void setup_io() {
       /* open /dev/mem */
       if ((mem_fd = open("/dev/mem", O_RDWR|O_SYNC) ) < 0) {
          printf("can't open /dev/mem \n");
          exit(-1);
       /* mmap GPIO */
       gpio_map = mmap(
          NULL,             //Any adddress in our space will do
          BLOCK_SIZE,       //Map length
          PROT_READ|PROT_WRITE,// Enable reading & writting to mapped memory
          MAP_SHARED,       //Shared with other processes
          mem_fd,           //File to map
          GPIO_BASE         //Offset to GPIO peripheral
       close(mem_fd); //No need to keep mem_fd open after mmap
       if (gpio_map == MAP_FAILED) {
          printf("mmap error %d\n", (int)gpio_map);//errno also set!
          exit(-1);
       // Always use volatile pointer!
       gpio = (volatile unsigned *)gpio_map;
    One time setup:
    gcc -o gpio_alt gpio_alt.c
    sudo chown root:root gpio_alt
    sudo chmod u+s gpio_alt
    sudo mv gpio_alt /usr/local/bin/
    Cron that:
    gpio_alt -p 13 -f 0
    gpio_alt -p 12 -f 0
  • boards ordered
    davedarko11/24/2016 at 16:04 2 comments
    There is currently no sound on this board, but I've ordered this anyway with some testpoints for the possible sound pins and an extra board you can check out below (not designed by me but someone who builds raspberry pi portables). The attiny85 is connected to the PI via I2C and the TFT LED output of the driver - think basic on/off via driver and pwm via i2c. It's a decent prototyping board to get along, I think.
    Gameboy Zero PWM Audio SMD - by Helder
    https://oshpark.com/shared_projects/qUEOjE0n
  • party on!
    davedarko11/19/2016 at 20:53 3 comments
    soo, still not validated, but I'm happy to give it a try as soon as possible - a breakout board to connect the Raspberry PI with the TFT display, wi-fi and I2C and stuff. I'm tired.
  • eyes for dem pis!
    davedarko11/18/2016 at 08:52 0 comments
    Yay, I won something! When I saw the blog post about the Enlightened Raspberry Pi Contest I must have over looked that I won something, because I was surprised when Adam Fabio wrote me to get my address to send me a sweet camera module! Not sure if it will end up in this project or the cluster thing, but I will find a good project for it! With all those PIs I have it shouldn't be a problem.
    https://hackaday.io/contest/15532/log/49182-and-the-winners-are
  • more wiring adventures
    davedarko11/10/2016 at 23:13 2 comments
  • Odyssey continues
    davedarko11/09/2016 at 20:55 1 comment
    Python script is about the same where I was before. Python is weird when you're coming from JS and PHP, let me tell you.
    AND the uinput part works!! woot! Thanks to adafruit, mainly. And my copy and paste skills.
    I still need to map the keys and find the driver for the display (MacGyver was drawn by an adafruit python library).
    import subprocess
    import sys
    import time
    import Adafruit_GPIO as GPIO
    import Adafruit_GPIO.I2C as I2C
    import Adafruit_GPIO.PCF8574 as PCF
    import uinput
    row = 1
    rowI = 1
    col = 1024
    addressH = 0x20
    addressL = 0x21
    gpioH = PCF.PCF8574(addressH, busnum=1)
    gpioL = PCF.PCF8574(addressL, busnum=1)
    KEY_MAPPING = {
                                    0: uinput.KEY_UP,    # Each line here should define a $
                                    1: uinput.KEY_DOWN,  # that maps the capacitive touch $
                                    2: uinput.KEY_LEFT,  # to an appropriate key press.
                                    3: uinput.KEY_RIGHT, #
                                    4: uinput.KEY_B,     # For reference the list of possi$
                                    5: uinput.KEY_A,     # values you can specify is defin$
                                    6: uinput.KEY_ENTER, # http://www.cs.fsu.edu/~baker/de$
                                    7: uinput.KEY_SPACE, # http/source/linux/include/linux$
    # Make sure uinput kernel module is loaded.
    subprocess.check_call(['modprobe', 'uinput'])
    # Configure virtual keyboard.
    device = uinput.Device(KEY_MAPPING.values())
    def shiftRange (start, end):
            while start > end:
                    yield start
                    start = start>>1
    while True:
            rowS = 0x03FF ^ row
            rowL = (rowS<<5) & 0x00FF
            rowH = (rowS>>3) & 0x00FF
            addL = rowL | 0x1F
            addH = rowH
            gpioH.iodir = addH
            gpioL.iodir = addL
            gpioH._write_pins()
            gpioL._write_pins()
            keys = gpioL._read_pins()
            keys = keys & 0x1F;
            keysI = 1
            for k in shiftRange(16,0):
                    if k & keys == 0:
                            device.emit_click(KEY_MAPPING[rowI-1])
                            time.sleep(0.5)
                    keysI += 1
            rowI += 1
            row = row << 1
            if row == col:
                    row = 1
                    rowI = 1
  • Keyboard adventures - Episode 2
    davedarko11/06/2016 at 00:53 0 comments
    That's my current state for the actual keyboard. I will probably drop this and move over to python, since I just don't get the uinput stuff in C and the linux input system. Hey future Dave, research before developing, you know this stuff!
    https://learn.adafruit.com/mpr121-capacitive-touch-sensor-on-raspberry-pi-and-beaglebone-black/software
    https://github.com/adafruit/Adafruit_Python_MPR121
    #include <wiringPi.h>
    #include <wiringPiI2C.h>
    #include <stdio.h>
    int fdH;
    int fdL;
    int fd;
    int rpl;
    int ret;
    int row = 1;
    int rowI = 1;
    int col = 1024;
    int i = 0;
    int j = 0;
    int k = 0;
    void printByte(int a)
            printf("\n0x");
            for (j=0x8000; j>0; j=j>>1)
                    if ((a&j) > 0) printf("1");
                    else printf("0");
    int main (void)
            wiringPiSetup ();
            fdH = wiringPiI2CSetup(0x20); // rows only
            fdL = wiringPiI2CSetup(0x21); // cols with rows
            for (;;)
                    int rowS = 0x03FF ^ row;
                    int rowL = (rowS<<5) & 0x00FF; // High
                    int rowH = (rowS>>3) & 0x00FF; // Low
                    int addL = rowL | 0x1F;
                    int addH = rowH;
                    wiringPiI2CWrite(fdH, addH);
                    wiringPiI2CWrite(fdL, addL);
                    int keys = wiringPiI2CRead(fdL);
                    keys = keys & 0x1F;
                    int keyI = 1;
                    for (k=0x10; k>0; k=k>>1)
                            if (!(k & keys))
                                    delay(50);
                                    printf("%i\t%i\n", keyI, rowI);
                            keyI++;
                    rowI++;
                    row = row << 1;
                    if (row == col)
                            row = 1;
                            rowI = 1;
            return 0 ;
  • I2C wiringPI for the PCF8574
    davedarko11/01/2016 at 22:29 0 comments
    It took me a while to get this far and I'm even further away from being done. I couldn't find a good example how to use the I2C library for it. http://wiringpi.com/reference/i2c-library/
    As I understand now, the function wiringPiI2CSetup gives you a file handle (everything in linux is a file, right?) and you need to store it! That's what I'm doing with the fd variable. Ignore the broken math, it's what I got from 4 hours raging on the keyboard after hours of work. From there you can use the fileHandler thing to read and write from and to. This way I got some data from a 4x4 keyboard.
    Little console helpers:
    i2cget -y 1 0x20
    i2cset -y 1 0x20 0x87
    gpio i2cd
    I also messed up the PCF8574 addressing pins :D of course I did. Here's my messy script.
    #include <stdio.h>
    int fd;
    int rpl;
    int row = 1;
    int col = 16;
    int main (void)
            fd = wiringPiI2CSetup(0x20);
            wiringPiSetup ();
            for (;;)
                    if (row>8)
                            row = 1;
                            col = col << 1;
                            if (col>128) col = 16;
                    rpl = wiringPiI2CWrite(fd, 240-col+row);
                    int b = wiringPiI2CRead(fd);
    //              printf("\t%i", 240-col);
    //              printf("\t%i", row);
    //              printf("\t%i\n", b);
                    if (b != 240-col+row)
                    printf("\t%i", b);
                            printf("\t%i\n", 240-col+row);
                            delay(250);
    // delay(250);
                    row*=2;
            return 0 ;
  • Updated 3D printing files
    davedarko10/31/2016 at 19:16 2 comments
    You can now download an print along :D only thing missing is the cover for the raspberry PI bottom. Notes came in handy.
View all 11 project logs
  • 1
    Step 1
    You have to 3D print the parts and have the boards for the keyboards ready
  • 2
    Step 2
    start with soldering the diodes to the keyboards, then the tactile button switches
  • 3
    Step 3
    Connect the two PCF8574 to the keyboards (also join together the row pins) and set the address pins differently.
View all 5 instructions
Craig Hissett wrote 11/18/2016 at 11:23 point
Congrats on making the finalist list mate!
You'll have to somehow work that Pi Camera into this now :-)
davedarko wrote 11/18/2016 at 11:41 point
I'd need the cable for that though
Craig Hissett wrote 11/18/2016 at 11:59 point
I'm sure a man of your ilk and skill could fudge one if the cable doesn't come with it :-)
To be honest i reckon a full length cable would be a nightmare to fit into a project so small.
davedarko wrote 11/18/2016 at 12:17 point
maybe I'll do another one that then is a foldable, then I will definitely add a camera ;) for now the case is designed in a very 'functional' way, not so much with aesthetics in mind... we'll see, first I would have to get the pi zero camera cable :)
jaromir.sukuba wrote 11/06/2016 at 10:39 point
What driver are you using for the display? I'm looking at project with rpi zero, this display and sound output via PWM pins on GPIO13 and GPIO18. Unfortunately, https://github.com/notro/fbtft uses GPIO18 as backlight control for this small ILI9340 display (configuration adafruit 2.2) and rebuilding it all looks like PITA, so I'm collecting other clues.
davedarko wrote 11/06/2016 at 10:50 point
so far I only used a python example to write an image... Pin18 is also used on @ajlitt wifi hat, so I wasnt looking into sound.
jaromir.sukuba wrote 11/06/2016 at 11:41 point
Thank you. Looks like I need three PWM pins and have only two of them, uhm. On/off for backlight should be enough.
davedarko wrote 11/06/2016 at 12:23 point
Maybe use a potentiometer like the Game Boy used for contrast.
davedarko wrote 11/10/2016 at 22:39 point
Seems like you don't have to recompile stuff, you can modprobe the pins and the PWM pins for the sound output are still free.
http://marcosgildavid.blogspot.de/2014/02/getting-ili9341-spi-screen-working-on.html
jaromir.sukuba wrote 11/11/2016 at 20:36 point
That makes things easier. Thanks for pointing this out.
zakqwy wrote 10/30/2016 at 17:25 point
I like the 3D printed case. The various compartments for wires and boards are somewhat reminiscent of the milled aluminum covers that enclose some RF circuits.
davedarko wrote 10/30/2016 at 18:52 point
it's more a happy little accident, but I like it none the less :) I wanted the battery to be protected and the usb charging board to be fixed in the case because of all the plugging in and out of the cable. I'll have to update the 3D files soon, before uploading them.
Craig Hissett wrote 10/27/2016 at 11:56 point
Oh, not again Dave...
Cash or Cheque?
davedarko wrote 10/27/2016 at 12:17 point
I've summoned the Craig.
Not yet ;)
Craig Hissett wrote 10/27/2016 at 12:42 point
You really need to stop making projects like this, I'm easily summoned these days ha ha!
In all seriousness it's great how it's taking shape. I've always been hung up on a gameboy style handheld but this is much better; plenty of functionality without being bulky or cumbersome to wield.
I can't wait to see the finished article!
jaromir.sukuba wrote 10/27/2016 at 10:58 point
The call in here https://hackaday.io/page/2325-keyboards-please was because of this project? Looks like you've chosen the most future-proof and repeatable solution, though not the best one. I fully understand.
I'm very curious how this one turns out.
davedarko wrote 10/27/2016 at 11:21 point
It was mainly because I wanted a PI zero portable, so yes :) Those buttons you were linking are perfect for this! They're easy to press and everything. I want to revisit the design to make it double sided with Letters on the silk print. I wasn't sure though that I'd really make it a project at first, that's why I made the page.
I hope I can make this a more 'programmers friendly' device, rather than a gaming console, so I wanted a keyboard.
jaromir.sukuba wrote 10/27/2016 at 12:06 point
So, you bought the particular keys from TME? Looks white, so the ones with smallest actuating force. Are you planning to give some keycaps/encapsulation/whatever to the keys?
I entered the "me too" crowd and bought the pi zero, pimoroni went out of stock shortly after my order :-) with the idea of building portable pi zero something. I have long history of portable computers (along with device programmers), with variable (generally low, though) degree of usefulness.
The display is really the cheap SPI 320x240?
davedarko wrote 10/27/2016 at 12:16 point
well these are the same keys, but I've bought them a tat bit cheaper on ebay. They're indeed white, I wanted the lowest force just to be sure and not wonder.
I have 5 PI zeros now, thx to social engineering at the makerFaire Berlin and repeated orders at pimoroni and felt bad when I told the pimoroni guys that I haven't actually done anything with them yet. There's always a small barrier in my head where I don't want to "waste" boards and the PI zero might be cheap but also hard to get. So I will keep this modular as far as I can, no heavy soldering on the PI.
I hope I can get an AVR programmer / other proggers on there as well, I took some inspiration from your projects.
It is indeed the ILI9340 SPI 320x240 display. I'll get bigger displays soon, but right now I'm quite happy with the general size.
