Found a bug in my Arduino driver
A project log for ADG2128 Breakout
A breakout board for Analog Devices' 8x12 analog cross-point switch
J. Ian LindsayJ. Ian Lindsay 11/20/2019 at 05:410 Comments
If you've bought one of the switch boards, and are trying to use my example sketch, I have an explanation for its failure to communicate with the board.
Please re-pull. This makes the default i2c address match the default jumper settings.
