Back after 3 month procrastination break!
A project log for The cargo1
A container for a Riese & Müller packster 80 that can be detached and used as a rolling suitcase
ØysteinØystein 04/06/2020 at 20:020 Comments
Finally more progress on the locking mechanism. I have acquired a gear wire I will use to actuate the locking mechanism and a spring so that the default state will be locked. A lever has been designed to attach the wire to and a body to house it is in the making.
V
The lever, housing for the lever and locking cam will be made out of aluminium. I have also made improvements to the locking cam design. The bolts are now m8 and locks into place using a triangle pocket.
Viddeo of function test below:
