Restore DFU Bootloader
A project log for 2019 Hackaday Superconference Badge
FPGA Running RISC-V Core in a Game Boy form factor
LutetiumLutetium 10/22/2019 at 13:360 Comments
Procedure to repair a damaged badge DFU (Device Firmware Update) partition.
Parts needed:
Procedure:
Info : JTAG tap: ecp5.tap tap/device found: 0x41112043 (mfg: 0x021 (Lattice Semi.), part: 0x1112, ver: 0x4)
> init
> svf bootloader.svf
[... lots of text trimmed ...]
svf file programmed successfully for 58 commands with 0 errors
> exit
dfu-util 0.9
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2016 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Found DFU: [1d50:614b] ver=0005, devnum=62, cfg=1, intf=0, path="1-2", alt=5, name="Bootloader", serial="e4692895a72b5c23"
Found DFU: [1d50:614b] ver=0005, devnum=62, cfg=1, intf=0, path="1-2", alt=4, name="Cartridge main FS region", serial="e4692895a72b5c23"
Found DFU: [1d50:614b] ver=0005, devnum=62, cfg=1, intf=0, path="1-2", alt=3, name="Cartridge IPL region", serial="e4692895a72b5c23"
Found DFU: [1d50:614b] ver=0005, devnum=62, cfg=1, intf=0, path="1-2", alt=2, name="Cartridge ECP5 bitstream", serial="e4692895a72b5c23"
Found DFU: [1d50:614b] ver=0005, devnum=62, cfg=1, intf=0, path="1-2", alt=1, name="RISC-V firmware (IPL)", serial="e4692895a72b5c23"
Found DFU: [1d50:614b] ver=0005, devnum=62, cfg=1, intf=0, path="1-2", alt=0, name="ECP5 bitstream (SoC)", serial="e4692895a72b5c23"
dfu-util -d 1d50:614a,1d50:614b -a 5 -D bootloader.bit
DFU mode device DFU version 0101
Device returned transfer size 4096
Copying data from PC to DFU device
Download    [=========================] 100%       279463 bytes
Download done.
state(2) = dfuIDLE, status(0) = No error condition is present
Done!
