Using OpenPnP
A project log for SimplePnP
Very low cost Pick and Place machine
ottoragamottoragam 09/04/2019 at 03:032 Comments
OpenPnP is a Java based open source software program that can be used with this machine in order to program and run PCB assembly jobs. This log will cover the configuration of machine drivers, head and feeders. In depth information about configuring OpenPnP can be found at https://github.com/openpnp/openpnp/wiki
Machine Drivers
A machine driver contains all the info pertaining the communication between a motion controller (GRBL in this case) and a computer running OpenPnP. SimplePnP uses two separate motion controllers, one for the table and another one for the head, so we need to set up the table driver and the head sub driver.
Table Driver Setup
Setting
Message
COMMAND_CONFIRM_REGEX
OK
CONNECT_COMMAND
$X
G90
HOME_COMMAND
$H
G92 X0 Y0 Z0
MOVE_TO_COMMAND
G1 {Y:X%.4f} {Y:Y%.4f} {X:Z%.4f} F{FeedRate:%.0f}
G4 P0
PICK_COMMAND
M8
PLACE_COMMAND
M9
Head Sub Driver
Setting
Message
OK
CONNECT_COMMAND
$X
G90
HOME_COMMAND
G92 X0 Y0 Z0
MOVE_TO_COMMAND
G1 {Z:X%.4f} {Rotation:Z%.4f} F{FeedRate:%.0f}
G4 P0
The machine.xml sub driver section should look like this:
Head
The head machine component has the information regarding the nozzle carriage and bottom looking camera parameters and capabilities. OpenPnP allows the user to set the preferred head parking location and the soft travel limits.
Nozzle
To set up a nozzle for the SimplePnP machine, the user needs to do the following:
Camera
James Newton wrote 09/11/2019 at 03:40 point
Java? Is it slow?
ottoragam wrote 09/11/2019 at 04:08 point
Not at all. Running on a 7 year old mid range PC.
