Design decisions
A project log for Playloop
Turn your phone into a retro gaming console
victor-dediosVictor Dedios 08/25/2019 at 09:040 Comments
A beginning
The problem itself seems to be pretty obvious once you've got to see the solution. But believe me, at least for me, I got a lot of though and work to get a suitable solution. I knew what specs I would like it to include as said:
 With this principles set up, I started designing the product, you can read about it on the next log. My main inspiration in this process and, from whom I learnt how ton face this problem, is one of the best designers of all times: Dieter Rams. He has 10 awesome principles when designing that I would like to share you just to end:
