Z-axis assembly and testing
A project log for Mekamantis
A fun and functional 3-axis hybrid parallel robot that fits on your desktop
Scott WinrothScott Winroth 08/24/2019 at 04:060 Comments
I finished assembling the z-axis and mobile platform support legs.  Everything fit together correctly and the legs move easily.  Unfortunately there is some sag in the mobile platform. The living hinges twist when the platform is extended away from the frame.  There doesn't seem to be an easy fix for this other than replacing the living hinges with standard hinges.
