Linear movement
A project log for ALEKYA - Open Source Construction Robot
A robotic system that aims to automate building construction using local building materials in developing countries.
Nishant AgarwalNishant Agarwal 08/25/2019 at 12:040 Comments
Now since the machine has two gantries on a single linear rail, the linear motion for each has to be independent of each other. Since I am using timing belts in my prototype, I had to use four lengths of them on the common linear axis. This can be done away with by using rack and pinions for motion which will be used in the next version of the machine and thereon.
I also came up my own belt 3d printed belt tensioning mechanism to use with the setup
