Progress with the real world prototype
A project log for ALEKYA - Open Source Construction Robot
A robotic system that aims to automate building construction using local building materials in developing countries.
nishant-agarwalNishant Agarwal 08/25/2019 at 13:290 Comments
While working on the protoype I have been learning and taking points for my next prototype which will be a real world application machine. I have started working on the 3d model.
After seeing that my designed linear rail mechanism works very well in th prototype I have decicded to use it on all the axes of the final prototype just with bigger bearing and hardware.
The design of the brick dispenser and the extruder need to be worked on some more.
