Screenshots
A project log for BRTRO-420 Better Blazin' Mod
Modify the BRTRO-420 reflow oven to have an Arduino based reflow firmware, serial interface and cold junction compensation.
bleckyBlecky 11/18/2019 at 13:490 Comments
There's now a screenshot command which generates an XBM bitmap over the serial port. Here's a few screenshots for your viewing pleasure. Note the ticks on the profile display, each tick represents 20 degrees (or 5 degrees per pixel) across the Y axis. As for seconds, each tick represents 20 seconds (or 5 seconds per pixel) across the X axis.
Main Screen:
Compare this to the existing display:
Config:
Profile:
Profile Edit:
Tools:
Test Out:
Reflow:
