We added the water pipe, pump and improvised reservoir.
We use an AC submerged water pump, the kind is used in aquariums , that is switched by a relay.
We added start and stop for the pump in the code and did a dry run to make sure all is working well.
Next we filled the reservoir, crossed our fingers and it worked like a charm ...
Watch the video
