ÜLGA (Üniversal Lute Generating Algorithm)
A method and means for creating an infinite variety of guitar-like stringed instruments using vectored fabrication.
0 followers
This project is an attempt to create a framework to create any conceivable stringed instrument. The project started as a means to generate custom versions of specific designs, but the system was robust enough to warrant expansion. This project uses a system called vectored fabrication to drive the manufacturing process.
multiscale neck generator.ipt
Basic parameter system for creating various necks.
ipt - 425.00 kB - 08/26/2019 at 05:22
Download
  • But, like with more style
    Andrew Benson08/26/2019 at 05:12 0 comments
  • Marabunta
    Andrew Benson08/26/2019 at 05:11 0 comments
    ÜLGA, the Üniversal Lute Generating Algorithm, was derived from Marabunta - a parametricly derived stringed instrument generator. Marabunta could create any neck and scale the body to fit - ÜLGA seemed a natural progression in allowing any body form to fit the derived instrument.
View all 2 project logs
