IOT project List
09/11/2019 at 14:46 • 0 commentsWith this board, we will make lots of IOT project.
1. A9G Publish DHT11 temperature and humidity to ThingSpeak via MQTT
2.Make a GPS Tracker.
3.ESP8266 Publishing DHT11 Readings with MQTT to Raspberry Pi
4.ESP8266 Publishing DHT22 Readings with MQTT to ThingSpeak
5.Publishing the SHT30 Readings with MQTT to ThingSpeak via WiFi and GPRS
IOTMCU
