Finishing rev1 of mainboard and power board
A project log for KZ80
A Z80 laptop
Kyle IsomKyle Isom 09/19/2019 at 14:460 Comments
The terminal blocks are in, so I finished assembling the mainboard and power board. I realized that I'd put the wrong part in the first power board (LD333V instead of an L7805), so I had to assemble a second power board (I guess this is why they send you three ;)). It passes the output checks (4.96 and 3.35V), and look at that clock signal!
