Propeller Weekender: Andy Schenk's Music Obj.!
Parallax Propeller plays our classic MIDI tunes from the SD-Card!
This time with Propeller's SD Card object with Andy Schenk's Music Synthesizer object: http://forums.parallax.com/discussion/111867/music-synthesizer-object-with-general-midi-sound-set
This is not a full tutorial on starting Propeller - there are various documentations around the Parallax website on that. I'm here on how to get the SD-Card and the Propeller working.
This is a follow-up from the earlier "Propeller Weekender" project: https://hackaday.io/project/167189-propeller-weekender-sd-card-experimentation
With the SD-Card working, it's time to test it with this little MIDI file player! Will it work? Should it need some more improvements? :)
Note: MIDI format 0 only supported!
gm_test.zip
Music Synth. Object by Andy Schenk. Some parts of the code modified to print onto the UART instead of a TV screen.
application/x-zip-compressed - 45.18 kB - 09/01/2019 at 14:23
Download
  • 1 × 47nF capacitor
  • 1 × 180R resistor
  • 1 × 100uF capacitor
  • All good, but I wanna hear it louder!
    YH-workshop09/01/2019 at 14:35 0 comments
    After testing the SD-Card object and worked very good the first time, I compiled this MIDI player by Andy Schenk ("Ariba" in the Propeller Forums). And I have loaded the "NUTRAC.MID" [MIDI format 0 only!] into the SD-Card as a test.
    I have changed some of the code to print the messages onto the UART instead of the TV screen. Pins 0 and 1 are to the speaker, and what he had recommended was this configuration:
    Unfortunately, the sound was barely audible. I stuck that 4ohm speaker to my ear (hopefully it didn't scream and break my eardrums!) and I could hear that tiny sound. Obviously, this needs amplification - I'm gonna figure out how to do this effectively!
View project log
