Latest Design Update
A project log for DIY Inkjet Printer
A piezo inkjet printer built from scratch
dominik-meffertDominik Meffert 07/16/2021 at 20:100 Comments
Here are some pictures of my latest printer design. It's not so different from the last design. The only changes are:
- New printhead which has a vacuum duct around the nozzles to suck in the excess ink.
- New driver electronics for switching the piezo discs - four IRFP460 that switch around 170VDC.
- Less 3D printed parts and cleaner look, because I placed the electronics in two boxes.
That's about it.
I tested it out and it works reliable even after not being in use for a day or two. After a short priming it is ejecting droplets again.
I'm currently using 0.2mm nozzles and the ejected droplets are quite large. Maybe I can change that by changing the switching time or by using even smaller nozzles.
But at least it's working now and should be usable for some test prints.
I uploaded the .stl files for it and will write building instructions for it as soon as possible.
