With the Bud Industries DCH-11923 enclosure arriving; the first round of layout testing has begun. Nothing will be set in stone until the PCB arrive so a proper fit can see seen. But the mock-up seems to fit correctly! :D System enable/disable (stop) may be mounted outside of the enclosure door but in a spot to not touch the high voltage wiring.
Jason
