Sliding modules
A project log for PULSE: BUILDING SMART DEVICES THE SIMPLE WAY
Control devices through a scriptable engine running on top of a microcontroller. Device has 2 SIMs, 2G, 3G, LTE, WiFi, LoRa, GPS and BT5
mgMG 11/12/2019 at 11:270 Comments
New system for connecting your own sensors and extending Pulse's functionality.
Apart from the 2 waterproof multiports, there is a drawer kind of mechanism. that allows you to slide in different modules in order to "host" your designs, while the rest of the device handles all the communication with le interwebz.
Some examples of a BNC sliding block, an I/O module (with crappy grommets at the moment) and an indoor air quality module.
