Easy Diy Pencil Holder
The pencil holder is quite a useful model. This box is useful for keeping pens, pencil, marker pens etc.
Public Chat
0 followers
This pencil holder can also be used in storing nuts, scissors, and other small items at home. After you have designed and printed, you can make it more attractive by using different colors to decorate it and make it more attractive.
You can design and print them for your kids or students (if you have) in order to make their studies more exciting and fun!
Learn more how it was created here youtu.be/jtwgqnXfU
box1.stl
Pencil Holder
Standard Tesselated Geometry - 4.11 MB - 09/07/2019 at 15:02
Download
box2.stl
Pencil Holder
Standard Tesselated Geometry - 5.66 MB - 09/07/2019 at 15:02
Download
  • 1 × 3D modeling software SelfCAD https://www.selfcad.com
  • 1 × 3D Printer Used for 3D printing the model that has been designed
  • 1 × 3D Printing materials 3D Printing material is used for 3d printing
  • 1
    Step 1
    To begin, follow this link to access SelfCAD software and launch it. https://www.selfcad.com.
    Then:
    •  Select a Standard Primitive - Cylinder
    •  Set the following parameters:
    1. Top and Bottom Cylinder radius 40
    2. Height 10
    3. Horizontal Segment 2
    4. Vertical segment 24
    5. Arc 360
  • 2
    Step 2
    • Rotate it by 90 degrees
  • 3
    Step 3
    • Make 2 copies with Copy Offsets Tool:
    1. For first model set value 200 on axis X
    2. For second model set -100 on axis X
View all 15 instructions
