Nixie Tube Clock
It's a nixie tube clock, there are many like it but this one is mine
This nixie tube clock uses old GR10M/U tubes driven by exixe12 tube drivers and an Arduino with an LCD shield just for ease of setup and use. The buttons on the LCD shield can be used to set the date and time, and a DS3231 RTC module is used to keep track of time when the clock is turned off.
- Tubes: http://www.tube-tester.com/sites/nixie/dat_arch/GR10M.pdf
- Exixe12 Drivers: https://www.tindie.com/products/dekuNukem/exixe-miniture-nixie-tube-driver-modules/
- Power Supply: https://www.ebay.com/itm/DC-5V-12V-to-180V-D
The case design was originally tested with plywood and subsequently "upgraded" to walnut.
Øystein wrote 09/09/2019 at 09:08 point
Nice build! The brass screws is a nice touch.
Dan Maloney wrote 09/13/2019 at 15:17 point
Agreed - always like he contrast of brass and a dark stained wood. Verry classy looking.
