Another lesson
A project log for Handheld 85
ATtiny85 based handheld game
matthew-reevesMatthew Reeves 10/02/2019 at 04:160 Comments
It seems I was using the clamp upside down.
If you put the chip in with the pins facing up then the clamp does a much better job holding the chip.
Then the red wire lines up with pin 1 on the chip.
