A project log for Bot-thoven: A Robot Musician
Designing a Servo Motor Based Mallet System to Generate Musical Expression in Instrument Playing Robots
Jason P.Jason P. 01/16/2020 at 14:520 Comments
Plan
I will need to build more servo-mallet systems so that I can test my code with more keys (and therefore play more interesting musical passages).
Procedures
I used the 3D Printer to print additional copies of the stand.
Progress
I was able to print additional copies of the stand for the servo-mallet system using the 3D printer. An image is shown above depicting the additional stands which were printed.
In addition, I was able to create additional servo-mallet systems so that I will be able to test my robot with passages consisting of more notes. An image is shown above depicting the additional servo-mallet systems created. I achieved my progress report goal which I set to accomplish by the end of January of “creating at least 15 servo-mallet systems.”
Problems
For next week, I will need to attach the servo-mallet systems I have created to the stands I have printed and connect it to the servo driver/Arduino to test if the servo-mallet systems function as intended.
