A project log for Bot-thoven: A Robot Musician
Designing a Servo Motor Based Mallet System to Generate Musical Expression in Instrument Playing Robots
jason-pJason P. 11/14/2019 at 14:200 Comments
Plan
This week, I will create CAD for the servo-mallet system prototypes I will be making.
Procedures
I used Fusion360 and the parts which arrived from Amazon to come up with an initial CAD design for the servo-mallet system.
Progress
The mallets, zip ties, and xylophone arrived through Amazon as pictured above.
I finished an initial CAD design showing how I will use the mallet, a servo, and zip tie to create a servo-mallet system to strike a xylophone key.
Problems
I will need to begin testing out the prototype by 3D printing the body (in green). By testing out the initial design, I will be able to make adjustments and changes as necessary to improve the servo-mallet system.
