PWM overlay
A project log for Raspberry Pi EVSE Hat
Use a Raspberry Pi to build an EV charging station
nick-sayerNick Sayer 08/27/2020 at 04:260 Comments
It turns out you can also dynamically turn on hardware pwm. Just run this (as root):
# dtoverlay pwm pin=18 func=2
That will make /sys/class/pwm/ and all of the rest show up and work.
