Battery Holder
A project log for Artemis 300 RTP Print Log
Keeping a log of my 3D prints
peter-mccloudPeter McCloud 11/24/2019 at 01:440 Comments
The first actual part I printed was the new battery holder for my Mk. II rotors. The Mk. I versons had been printed with a Formlabs 2 using the durable resin and they've worked well. I wanted to get some test prints to make sure they will fit with the new hardware and see if the PLA prints would be functional.
Slicing and printing was straight forwards. I'd attempting a version without the brim, but the corners would peel up pretty quickly. My default when using the Artemis has been to just include the brim. I was pretty happy with the print. The only negative point was a small separation between one of the outer layers and the inner layers in one spot.
Cleanup was quick and the battery fit perfect.
