First stab
A project log for MPPT for low voltage solar harvesting
Microcontrollers + caps = MPPT in the time domain?
Simon MerrettSimon Merrett 09/16/2019 at 21:561 Comment
How about this?
vr2045 wrote 09/16/2019 at 22:28 point
Cool!
- Assuming this is indoors, you will likely need a boost converter to maximize power from the solar cell. THis could be implemented as a switch and inductor, switch driven by U1. Will allow you to draw power from the solar cell even when its output voltage is below 1.8V.
- Leakage from 100K resistors are likely to be large contributors if the device is on infrequently. You may want to change R1/R4, R3/R5 to >1M to minimize leakage
- Consider a resistor on the PA2 output to limit max current draw into the caps
