We succeeded in transmitting data over a range of 32 meter.
Aiming the blasters became impractical at a range of about 25 meters.
We tested outside in the dark to eliminate interference from the sun.
Technical specs:
- IR carrier frequency: 38 kHz
- IR switch frequency: 1000 Hz
- blaster power supply: 5 V for transmitter, 3.6 V for receiver.
To send data we turn the 38 kHz carrier frequency on and off.
The duration of the on + off length determines the type of signal (start, 0, 1, stop)
| time on in ms (1000 Hz) | time off in ms | |
| Start | 8 | 16 |
| logical 1 | 1 | 1 |
| logical 0 | 1 | 3 |
| Stop | 1 | 1+ |
This is loosely based on the NEC IR protocol.
sending one bit takes 2 ms on average, excluding the start and stop bit.
hans polders
