RGB test
A project log for Time Blaster
IR blaster to be used with the Fri3dcamp 2020 badge
wim-van-goolWim Van Gool 12/10/2019 at 07:350 Comments
After burning the Arduino bootloader, a quick test was uploaded and so far the LEDs seem to work as expected. Although the Through Hole has Red and Green swapped compared to the SMD WS2812b LEDs.
