Interrupts
A project log for Boat Ventilator Control
Controlling a fan and protecting the battery on my boat on the cheap; using an ATTiny85 and a DHT11 temperature and humidity sensor
owenOwen 09/30/2019 at 14:220 Comments
I had time recently to look at the Interrupt routines I want to use; got a couple of ATTiny examples working, one for timer and the other for a pin interrupt.
I will use sleep mode for the times between readings, but one of the relatively hight power modes that leave the PWM running. I might investigate using super low power mode for battery low conditions, in these modes even the PWM is off, but if the fan is running I need to limit sleep mode to one of the mid states.
