Post install refresh
A project log for Boat Ventilator Control
Controlling a fan and protecting the battery on my boat on the cheap; using an ATTiny85 and a DHT11 temperature and humidity sensor
owenOwen 06/18/2020 at 14:370 Comments
So, this is now installed and running in my boat
And I have spent some time refactoring the archive, and updating the documentation/readme's
It's still not perfect, but should be easier to navigate and understand.
I will come back to this later since I still want to use an interrupt/timer for the primary sleep loop. Currently I just use a delay(), in idle mode the Digispark is only drawing a couple of mA.
