I2C indication
A project log for Homebrew CP/M-computer powered by Arduino Nano
Homebrew computer under CP/M with TV Out and PS/2 keyboard powered by Arduino Nano
alexey-voroninAlexey Voronin 12/10/2020 at 17:160 Comments
Added indication of access to the I2C bus (in fact, access to FRAM) - an LED that lights up when the SCL line is low. The quick-and-dirty approach to connect the LED through a 2 kOhm resistor did not pass at all - there was not a single memory module on the bus - it turned out to be too strong pull-up, although it worked after 4.7 kOhm, but in 7407 there are free pins, so through this buffer it turned out more reliable.
Now the RAM "module" schematic looks like this:
