Today i have replaced the l298n driver motor with a DRV8833.
My base is using 4 x DC 3-6V motor and the chip has only 4 pinout. I made some "Y" dupont cable for the "H" bridge, and after some tests, it's working. so the like the l298n, the DRV8833 can handle 4 motors.
Here is my test code for the arduino in C++:
#include <Arduino.h>
// Serial Debug
const unsigned long BAUD_RATE=115200;
#define pinINA1 6 // Moteur A, entrée 1 - Commande en PWM possible
#define pinINA2 7 // Moteur A, entrée 2 - Commande en PWM possible
#define pinINA3 8 // Moteur B, entrée 1 - Commande en PWM possible
#define pinINA4 9 // Moteur B, entrée 2 - Commande en PWM possible
void setup(){
Serial.begin(115200);
Serial.println("Test DRV8833");
// Initialize les broches de commandes DRV8833
// du moteur A
pinMode( pinINA1, OUTPUT );
digitalWrite( pinINA1, 1 );
digitalWrite( pinINA2, 1 );
// du moteur B
pinMode( pinINA3, OUTPUT );
pinMode( pinINA4, OUTPUT );
digitalWrite( pinINA3, 1 );
digitalWrite( pinINA4, 1 );
void loop(){
// --- Moteur A: Controle pleine puissance -------------------
// Marche avant
Serial.println("Marche avant");
digitalWrite( pinINA1, HIGH );
digitalWrite( pinINA2, LOW );
digitalWrite( pinINA3, HIGH );
digitalWrite( pinINA4, LOW );
delay( 3000 );
// Arret par frein (voir documentation)
Serial.println("Stop");
digitalWrite( pinINA1, LOW );
digitalWrite( pinINA3, LOW );
delay( 2000 );
Before PWM on motor was not working (changing the speed of the motors). Now i can change the speed of the motors and they make less sounds noise.
I'm using toys motors for testing the thing. i plan to replace them soon.
Here is some part of the project, unmounted :
Thank you for reading me and have a good day.
