03.10.2019 - installating OpenCV on RPI3B with ubuntu
A project log for VT-01 - robotic project
a Versatile robotic platform for various tasks.
nj1337nj1337 10/02/2019 at 23:250 Comments
today i was checking some website for computer vision. And i think i will use an intel D415 or D435 cam depth camera. But it's not supported in raspbian. So i decided to install ubuntu on my Raspberry Pi 3.
Here is how to to do this.
First, grab the archive from ubuntu, then write it to your SD car. I'm using rufus for this operation.
When done, put your SDcard in the RPi3 and boot. Make the first configuration ... keyboard, location ...
Once this done, install SSHd :
apt remove openssh-server
apt install openssh-server
systemctl disable sshguard
systemctl enable openssh-server
Go to your main computer and connect with SSH, then purge some useless packages
sudo su
apt-get remove --purge libreoffice*
apt-get clean
apt-get autoremove
Update the OS :
sudo apt update && sudo apt upgrade -y
I'm the current version (beta), there is a bug with the firmeware, you need to force it
sudo dpkg -i --force-all /var/cache/apt/archives/linux-firmware-raspi2_1.20190215-0ubuntu0.18.04.1_armhf.deb
I need screen, cause i'm working with SSH and i dont want to loose my session :
apt install screen
 Then install RDP, so you can connect from windows easly :
sudo apt install xrdp
sudo systemctl enable xrdp
Now we can start OpenCV 4.X installation :
First, make the swap bigger :
swapoff /swapfile
rm  /swapfile
dd if=/dev/zero of=/swapfile bs=1M count=2048
chmod 600 /swapfile
mkswap /swapfile
swapon /swapfile
Then, install some needed packages :
apt install build-essential cmake git pkg-config libgtk-3-dev "libcanberra-gtk*"
apt install libavcodec-dev libavformat-dev libswscale-dev libv4l-dev libxvidcore-dev libx264-dev
apt install libjpeg-dev libpng-dev libtiff-dev gfortran openexr libatlas-base-dev opencl-headers
apt install python3-dev python3-numpy libtbb2 libtbb-dev libdc1394-22-dev
 Go back to your user and download openCV with git :
exit
mkdir ~/opencv_build && cd ~/opencv_build
git clone https://github.com/opencv/opencv.git
git clone https://github.com/opencv/opencv_contrib.git
mkdir -p ~/opencv_build/opencv/build && cd ~/opencv_build/opencv/build
screen a new session :
screen
 hit space
then cmake the thing :
cmake -D CMAKE_BUILD_TYPE=RELEASE \
    -D CMAKE_INSTALL_PREFIX=/usr/local \
    -D INSTALL_C_EXAMPLES=OFF \
    -D INSTALL_PYTHON_EXAMPLES=OFF \
    -D OPENCV_GENERATE_PKGCONFIG=ON \
    -D ENABLE_NEON=ON \
    -D OPENCV_EXTRA_EXE_LINKER_FLAGS=-latomic \
    -D ENABLE_VFPV3=ON \
    -D BUILD_TESTS=OFF \
    -D OPENCV_ENABLE_NONFREE=ON \
    -D OPENCV_EXTRA_MODULES_PATH=~/opencv_build/opencv_contrib/modules \
    -D BUILD_EXAMPLES=OFF ..
then compile the monster :
make -j4
if make stop or hang, just restart it without the -j4
Make a coffee, grab a good netflix film, and stay relax for 2/3 hours.
Once done, install the compiled thing :
sudo make install
DONE
Check if it's working :
for C++ :
pkg-config --modversion opencv4
For python :
python3 -c "import cv2; print(cv2.__version__)"
lets get back to previous swap file :
 sudo su
swapoff /swapfile
rm  /swapfile
dd if=/dev/zero of=/swapfile bs=1M count=1024
chmod 600 /swapfile
mkswap /swapfile
swapon /swapfile
Have fun =)
