Hack Chat Transcript, Part 3
A event log for High-Speed PCB Design with Bil Herd
Square traces? No problem! Probably
lutetiumLutetium 09/25/2019 at 20:580 Comments
Bil Herd1:04 PM
I will be talking about PCB fab in the next viddeo. I will try and work in some of these questions into that
Bil Herd1:04 PM
Thanks everyone!
Nicolas Tremblay left  the room.1:04 PM
Bil Herd1:04 PM
@frank Give me an hour with ya and I could have ya doing Gig stuff!
Frank Buss1:05 PM
I'm just a programmer, tinkering a bit with hardware :-)
Paul Stoffregen1:05 PM
Didn't wanna interrupt earlier with an off-topic question... but hopefully ok now to ask if anyone's done a PCB design using 0.4 mm pitch BGA? I'm considering one soon (a 36 pin BGA). Any tips?
Bil Herd1:05 PM
Just to add, the stuff we did on 2 sided boards in the 80's was just awful, I would use 40-80 series resistors in a design
Bil Herd1:06 PM
@Paul Stoffregen Are you doing it yourself? What CAD package?
Paul Stoffregen1:07 PM
Yup. I'm a bit embarrassed to admit it, but I use an ancient version of PADS. It still works pretty well for me.
Bil Herd1:07 PM
@Frank Buss you know this stuff. You were asking the right questions in that other forum on FB. ;)
Ben Jordan1:07 PM
@Paul Stoffregen 0.4mm pitch - you will have to use Via-In-Pad HDI
Bil Herd1:08 PM
PADs is one of the progenitors of the industry.
Ben Jordan1:08 PM
I have a reference design I can send you with a freescale I.MX8 CPU if you like?
Paul Stoffregen1:08 PM
I guess that means I need to learn how to buy a PCB with via-in-pad... never done that befer
*before
Bil Herd1:08 PM
@Ben Jordan I would love a copy if you could email me at bilherd@hackaday dot com
Ben Jordan1:09 PM
will do
Chris Hamilton1:09 PM
@Paul Stoffregen you might be able to use thin traces which is slightly cheaper.
Adam Oakley1:09 PM
I've never had a manufacturer complain about via-in-pad, and I don't take any special steps to warn them or anything
https://hackaday.io/event/167712-high-speed-pcb-design-with-bil-herd/log/169237-hack-chat-transcript-part-1
HACKADAY
Hack Chat Transcript, Part 1 | Details | Hackaday.io
Well, we've been having some good sidebar discussion here for a bit, but let's kick it off officially and welcome Bil Herd to the Hack Chat. Today we're going to learn about high-speed PCB design. Bil, I usually ask hosts to introduce themselves to get things going, but that seems silly here.
Read this on Hackaday
Paul Stoffregen1:09 PM
so you give them more than one drill file?
Ben Jordan1:10 PM
generally they know how to do it these days...
Bil Herd1:10 PM
I know someone that is as dedicated to PCB layout as I am to hardware. I run questions like .4mm by him in the form of "yes buyt what works in production?"
Adam Oakley1:10 PM
no, are you referring to via-in-pad with filling or something?
Ben Jordan1:10 PM
yes different drill files for each drill layer pair will be needed
Bil Herd1:10 PM
We were talking earlier about via in pad and sealing them and hot gasses
Ben Jordan1:11 PM
yeah if it's hdi, fabs will often plate them up to solid copper - no outgassing problems there
Ben Jordan1:11 PM
ballpark figures may be obtained by US based fabs
Bil Herd1:11 PM
I just read "The Designer's HANDBOOK for DFM" by Sierra Circuits, (DFM is design for manufacturing), I recommend it
Ben Jordan1:12 PM
was going to mentione Sierra!
Frank Buss1:12 PM
@Bil Herd do you mean this?
https://www.facebook.com/groups/CommanderX16/permalink/524160045001761/?comment_id=524251758325923&reply_comment_id=524333631651069
I think they will get into trouble, when they try to access the YM2151 with an 8 MHz clocked X16, it just works by chance now. But at least they can switch it to 4 MHz, but I think a latch to make the signal and data longer would be better.
Bil Herd1:12 PM
I am looking for the link, a good read for 80 pages... of course I printed it rather than read it online
Bil Herd1:13 PM
@Frank Buss ;)
Jakub Sadowski1:13 PM
What website do you recommend to ask specific question about high speed/RF magic in PCB designs?
Bil Herd1:15 PM
Check out the Signal Integrity Journal , give me a sec and I will pull links.
Frank Buss1:15 PM
looks like there are other things they do by trial and error, like using a TL084 with just +5V / 0V. The designer said it works stable with a big enough capacitor :-)
Bil Herd1:15 PM
DFM_handbook_digital.pdf
1 MB
Download File
Bil Herd1:15 PM
See if that pdf is readable.\
Paul Stoffregen1:16 PM
yup, got it, 77 pages :)
Bil Herd1:16 PM
@Frank Buss ;)
aerispalm1:16 PM
because you said i was talking about differential pairs, i actually wasn't it just got recommended to me to keep all datalines at the same length because the protocoll is counting on them to arrive at the same time, so does that not actually matter?
Bil Herd1:16 PM
https://www.bethesignal.com/
BETHESIGNAL
Teledyne LeCroy SI Academy
Learn signal integrity problem solving skills from the Signal Integrity Evangelist, Dr. Eric Bogatin. Did you miss one of Eric's popular live classes? At the Teledyne LeCroy Signal Integrity Academy, you can explore all his past classes and many new ones, broken down into short, concise, video lessons.
Read this on Bethesignal
Adam Oakley1:16 PM
I remember an older engineer telling me about how he used hex inverter chips as opamps, quite interesting
Bil Herd1:17 PM
@aerispalm not NEAR as critical as we used to say, in fact I have changed my viewpoint a little.
Bil Herd1:17 PM
If you are off by half an inch at 2/3rds the speed of ligh you are still pretty darn close
Bil Herd1:17 PM
light
Bil Herd1:18 PM
a signal propagates 6" in a ns on a standard PCB
Bil Herd1:18 PM
its like square corners, which we didn't get to, it goes by so dang fast that it gets lost in a rounding error
Frank Buss1:18 PM
@Adam Oakley how does this work? an inverter gate has only one input
Bil Herd1:19 PM
https://speedingedge.com/products/right-first-time/
SPEEDINGEDGE
Right the First Time, A Practical Handbook on High-Speed PCB and System Design
"Right the First Time, A Practical Handbook on High Speed PCB and System Design, Volume 1," is the premier publication of Speeding Edge. It was written by Speeding Edge founder and president, Lee W. Ritchey, co-authored by John Zasio, an recognized industry expert in high-speed design, and edited by Kella J.
Read this on Speedingedge
Bil Herd1:19 PM
Whoops that was meant to be a link to Lee's site, not an ad for his book
Adam Oakley1:19 PM
I wish I had asked more about that, something about biasing it in a certain way to use it as an amplifier
Bil Herd1:19 PM
https://www.signalintegrityjournal.com/
SIGNALINTEGRITYJOURNAL
Home Page
Signal Integrity Journal, a sister publication to Microwave Journal, covers signal integrity, power integrity and EMC/EMI related topics with industry news, technical articles, white papers, products, Buyer's Guide, webinars, videos and more. The vision for the SI Journal is to increase the signal to noise ratio for SI, PI and EMC engineers by providing high value content.
Read this on Signalintegrityjournal
Bil Herd1:20 PM
We have changed what we thought we knew about decoupling caps, now we get caught in the anti-resonance of teh caop since caps are also.... wait for it... Inductors
Bil Herd1:21 PM
"the decoupling cap"
Adam Oakley1:23 PM
https://wiki.analog.com/university/courses/electronics/electronics-lab-20 here's an article about the hex inverter amplifier
john1:23 PM
Interesting. I'll look into it.
Frank Buss1:25 PM
thanks, looks like an interesting hack :-)
Bil Herd1:29 PM
I used to bias the 4000 series CMOS inverters into amps. I made an ultrasonic blind spot detector in the 80's that fit in a running light using ahex invertors as analog amps
